HwB: Zorro II/III Connector
Zorro II/III
(At the computer)
100 PIN EDGE CONNECTOR at the computer.
Pin | Physical Name |
Zorro II Name |
Zorro III Address Phase |
Zorro III Data Phase |
1 | Ground | Ground | Ground | Ground |
2 | Ground | Ground | Ground | Ground |
3 | Ground | Ground | Ground | Ground |
4 | Ground | Ground | Ground | Ground |
5 | +5VDC | +5VDC | +5VDC | +5VDC |
6 | +5VDC | +5VDC | +5VDC | +5VDC |
7 | /OWN | /OWN | /OWN | /OWN |
8 | -5VDC | -5VDC | -5VDC | -5VDC |
9 | /SLAVEn | /SLAVEn | /SLAVEn | /SLAVEn |
10 | +12VDC | +12VDC | +12VDC | +12VDC |
11 | /CFGOUTn | /CFGOUTn | /CFGOUTn | /CFGOUTn |
12 | /CFGINn | /CFGINn | /CFGINn | /CFGINn |
13 | Ground | Ground | Ground | Ground |
14 | /C3 | /C3 Clock | /C3 Clock | /C3 Clock |
15 | CDAC | CDAC Clock | CDAC Clock | CDAC Clock |
16 | /C1 | /C1 Clock | /C1 Clock | /C1 Clock |
17 | /CINH | /OVR | /CINH | /CINH |
18 | /MTCR | XRDY | /MTCR | /MTCR |
19 | /INT2 | /INT2 | /INT2 | /INT2 |
20 | -12VDC | -12VDC | -12VDC | -12VDC |
21 | A5 | A5 | A5 | A5 |
22 | /INT6 | /INT6 | /INT6 | /INT6 |
23 | A6 | A6 | A6 | A6 |
24 | A4 | A4 | A4 | A4 |
25 | Ground | Ground | Ground | Ground |
26 | A3 | A3 | A3 | A3 |
27 | A2 | A2 | A2 | A2 |
28 | A7 | A7 | A7 | A7 |
29 | /LOCK | A1 | /LOCK | /LOCK |
30 | AD8 | A8 | A8 | D0 |
31 | FC0 | FC0 | FC0 | FC0 |
32 | AD9 | A9 | A9 | D1 |
33 | FC1 | FC1 | FC1 | FC1 |
34 | AD10 | A10 | A10 | D2 |
35 | FC2 | FC2 | FC2 | FC2 |
36 | AD11 | A11 | A11 | D3 |
37 | Ground | Ground | Ground | Ground |
38 | AD12 | A12 | A12 | D4 |
39 | AD13 | A13 | A13 | D5 |
40 | Reserved | (/EINT7) | Reserved | Reserved |
41 | AD14 | A14 | A14 | D6 |
42 | Reserved | (/EINT5) | Reserved | Reserved |
43 | AD15 | A15 | A15 | D7 |
44 | Reserved | (/EINT4) | Reserved | Reserved |
45 | AD16 | A16 | A16 | D8 |
46 | /BERR | /BERR | /BERR | /BERR |
47 | AD17 | A17 | A17 | D9 |
48 | /MTACK | (/VPA) | /MTACK | /MTACK |
49 | Ground | Ground | Ground | Ground |
50 | E Clock | E Clock | E Clock | E Clock |
51 | /DS0 | (/VMA) | /DS0 | /DS0 |
52 | AD18 | A18 | A18 | D10 |
53 | /RESET | /RST | /RESET | /RESET |
54 | AD19 | A19 | A19 | D11 |
55 | /HLT | /HLT | /HLT | /HLT |
56 | AD20 | A20 | A20 | D12 |
57 | AD22 | A22 | A22 | D14 |
58 | AD21 | A21 | A21 | D13 |
59 | AD23 | A23 | A23 | D15 |
60 | /BRn | /BRn | /BRn | /BRn |
61 | Ground | Ground | Ground | Ground |
62 | /BGACK | /BGACK | /BGACK | /BGACK |
63 | AD31 | D15 | A31 | D31 |
64 | /BGn | /BGn | /BGn | /BGn |
65 | AD30 | D14 | A30 | D30 |
66 | /DTACK | /DTACK | /DTACK | /DTACK |
67 | AD29 | D13 | A29 | D29 |
68 | READ | READ | READ | READ |
69 | AD28 | D12 | A28 | D28 |
70 | /DS2 | /LDS | /DS2 | /DS2 |
71 | AD27 | D11 | A27 | D27 |
72 | /DS3 | /UDS | /DS3 | /DS3 |
73 | Ground | Ground | Ground | Ground |
74 | /CCS | /AS | /CCS | /CCS |
75 | SD0 | D0 | Reserved | D16 |
76 | AD26 | D10 | A26 | D26 |
77 | SD1 | D1 | Reserved | D17 |
78 | AD25 | D9 | A25 | D25 |
79 | SD2 | D2 | Reserved | D18 |
80 | AD24 | D8 | A24 | D24 |
81 | SD3 | D3 | Reserved | D19 |
82 | SD7 | D7 | Reserved | D23 |
83 | SD4 | D4 | Reserved | D20 |
84 | SD6 | D6 | Reserved | D22 |
85 | Ground | Ground | Ground | Ground |
86 | SD5 | D5 | Reserved | D21 |
87 | Ground | Ground | Ground | Ground |
88 | Ground | Ground | Ground | Ground |
89 | Ground | Ground | Ground | Ground |
90 | Ground | Ground | Ground | Ground |
91 | SenseZ3 | Ground | SenseZ3 | SenseZ3 |
92 | 7M | E7M | 7M | 7M |
93 | DOE | DOE | DOE | DOE |
94 | /IORST | /BUSRST | /IORST | /IORST |
95 | /BCLR | /GBG | /BCLR | /BCLR |
96 | Reserved | (/EINT1) | Reserved | Reserved |
97 | /FCS | No Connect | /FCS | /FCS |
98 | /DS1 | No Connect | /DS1 | /DS1 |
99 | Ground | Ground | Ground | Ground |
100 | Ground | Ground | Ground | Ground |
