QRZ.RU > Технические справочники > HwB: The Hardware Book (Mirror) > HwB: Amiga Video Expansion Connector
Video Expansion (Amiga)
(At the
computer)
36+54 PIN EDGE CONNECTOR at the computer.
Pin | Name | Dir | Description |
1 | RGB16 | ![]() |
Red Bit 0 |
2 | RGB17 | ![]() |
Red Bit 1 |
3 | LINELF | ![]() |
Audio Line Out Left |
4 | LINERT | ![]() |
Audio Line Out Right |
5 | C28D | ![]() |
Pixel-Synchronous Clock |
6 | +5V | - | +5 Volts DC (1 A) |
7 | ARED | ![]() |
Analog Red |
8 | +5V | - | +5 Volts DC (1 A) |
9 | GND | - | Digital Ground |
10 | +12V | - | +12 Volts DC (40 mA) |
11 | AGREEN | ![]() |
Analog Green |
12 | GND | - | Digital Ground |
13 | GND | - | Digital Ground |
14 | /CSYNC | ![]() |
Composite Sync |
15 | ABLUE | ![]() |
Analog Blue |
16 | /XCLKEN | ![]() |
Genlock Clock Enable |
17 | GND | - | Digital Ground |
18 | BURST | ![]() |
Burst Gate |
19 | /C4 | ![]() |
3.55/3.58 MHz Clock |
20 | GND | - | Digital Ground |
21 | GND | - | Digital Ground |
22 | /HSYNC | ![]() |
Horizontal Sync (47 Ohm) |
23 | RGB4 | ![]() |
Blue Bit 4 |
24 | GND | - | Digital Ground |
25 | RGB7 | ![]() |
Blue Bit 7 |
26 | /VSYNC | ![]() |
Vertical Sync (47 Ohm) |
27 | RGB15 | ![]() |
Green Bit 7 |
28 | BLANK | ![]() |
Video Blank |
29 | RGB23 | ![]() |
Red 7 |
30 | /PIXELSW | ![]() |
Genlock Overlay (47 Ohm) |
31 | -5V | - | -5 Volts DC |
32 | GND | - | Digital Ground |
33 | /XCLK | ![]() |
Genlock Clock |
34 | /C1 | ![]() |
C1 Clock |
35 | +5V | - | +5 Volts DC (1 A) |
36 | PSTROBE | ![]() |
Printer Port Handshake |
2 | RGB20 | ![]() |
Red Bit 4 |
3 | RGB21 | ![]() |
Red Bit 5 |
4 | RGB22 | ![]() |
Red Bit 6 |
5 | GND | - | Digital Ground |
6 | RGB12 | ![]() |
Green Bit 4 |
7 | RGB13 | ![]() |
Green Bit 5 |
8 | RGB14 | ![]() |
Green Bit 6 |
10 | RGB5 | ![]() |
Blue Bit 5 |
11 | RGB6 | ![]() |
Blue Bit 6 |
12 | GND | - | Ground |
13 | SOG | ![]() |
Sync-On-Green Indicator |
14 | TBASE | ![]() |
50/60 Hz Software Clock Timebase |
15 | CDAC | ![]() |
7.09/7.16 MHz Clock |
16 | PPOUT | ![]() |
Printer Port Paper Out |
17 | /C3 | ![]() |
18 | PBUSY | ![]() |
Printer Port Busy |
19 | /LPEN | ![]() |
Light Pen Input |
20 | /PACK | ![]() |
Printer Port Acknowledge Handshake |
21 | PSEL | ![]() |
Printer Port Select |
22 | GND | - | Digital Ground |
23 | PPD0 | ![]() |
Printer Port Data Bit 0 |
24 | PPD1 | ![]() |
Printer Port Data Bit 1 |
25 | PPD2 | ![]() |
Printer Port Data Bit 2 |
26 | PPD3 | ![]() |
Printer Port Data Bit 3 |
27 | PPD4 | ![]() |
Printer Port Data Bit 4 |
28 | PPD5 | ![]() |
Printer Port Data Bit 5 |
29 | PPD6 | ![]() |
Printer Port Data Bit 6 |
30 | PPD7 | ![]() |
Printer Port Data Bit 7 |
31 | /LED | ![]() |
LED (Audio filter bypass) Setting |
33 | RAWLF | ![]() |
Raw (Unfiltered) Audio Left |
34 | AGND | - | Audio Ground |
35 | RAWRT | ![]() |
Raw (Unfiltered) Audio Right |
36 | AGND | - | Audio Ground |
37 | n/c | - | Reserved for future expansion |
38 | n/c | - | Reserved for future expansion |
39 | GND | - | Digital Ground |
40 | GND | - | Digital Ground |
41 | n/c | - | Reserved for future expansion |
42 | n/c | - | Reserved for future expansion |
43 | GND | - | Digital Ground |
44 | GND | - | Digital Ground |
45 | RGB18 | ![]() |
Red Bit 2 |
46 | RGB19 | ![]() |
Red Bit 3 |
47 | RGB8 | ![]() |
Green Bit 0 |
48 | RGB9 | ![]() |
Green Bit 1 |
49 | RGB10 | ![]() |
Green Bit 2 |
50 | RGB11 | ![]() |
Green Bit 3 |
51 | RGB0 | ![]() |
Blue Bit 0 |
52 | RGB1 | ![]() |
Blue Bit 1 |
53 | RGB2 | ![]() |
Blue Bit 2 |
54 | RGB3 | ![]() |
Blue Bit 3 |
Note: Do not mix analog & digital grounds. Contributor: Joakim Цgren Source: Amiga 4000 User's Guide from Commodore Please send any comments to Joakim Цgren.
