HwB: VESA Feature Connector
VESA Feature
(At the videocard)
26 PIN IDC at the Video card.
Pin | Name | Description |
1 | PD0 | DAC Pixel Data Bit 0 (PB) |
2 | PD1 | DAC Pixel Data Bit 1 (PG) |
3 | PD2 | DAC Pixel Data Bit 2 (PR) |
4 | PD3 | DAC Pixel Data Bit 3 (PI) |
5 | PD4 | DAC Pixel Data Bit 4 (SB) |
6 | PD5 | DAC Pixel Data Bit 5 (SG) |
7 | PD6 | DAC Pixel Data Bit 6 (SR) |
8 | PD7 | DAC Pixel Data Bit 7 (SI) |
9 | CLK | DAC Clock |
10 | BLK | DAC Blanking |
11 | HSYNC | Horizontal Sync |
12 | VSYNC | Vertical Sync |
13 | GND | Ground |
14 | GND | Ground |
15 | GND | Ground |
16 | GND | Ground |
17 | Select Internal Video | |
18 | Select Internal Sync | |
19 | Select Internal Dot Clock | |
20 | n/c | Not used |
21 | GND | Ground |
22 | GND | Ground |
23 | GND | Ground |
24 | GND | Ground |
25 | n/c | Not used |
26 | n/c | Not used |
