HwB: VGA (15) Connector
VGA (15)
VGA=Video Graphics Adapter or Video Graphics Array.
Videotype: Analogue.
(At
the videocard)
(At
the monitor cable)
15 PIN HIGHDENSITY D-SUB FEMALE at the videocard.
15 PIN HIGHDENSITY D-SUB MALE at the monitor cable.
Pin | Name | Dir | Description |
1 | RED | ![]() |
Red Video (75 ohm, 0.7 V p-p) |
2 | GREEN | ![]() |
Green Video (75 ohm, 0.7 V p-p) |
3 | BLUE | ![]() |
Blue Video (75 ohm, 0.7 V p-p) |
4 | ID2 | ![]() |
Monitor ID Bit 2 |
5 | GND | ![]() |
Ground |
6 | RGND | ![]() |
Red Ground |
7 | GGND | ![]() |
Green Ground |
8 | BGND | ![]() |
Blue Ground |
9 | KEY | - | Key (No pin) |
10 | SGND | ![]() |
Sync Ground |
11 | ID0 | ![]() |
Monitor ID Bit 0 |
12 | ID1 or SDA | ![]() |
Monitor ID Bit 1 |
13 | HSYNC or CSYNC | ![]() |
Horizontal Sync (or Composite Sync) |
14 | VSYNC | ![]() |
Vertical Sync |
15 | ID3 or SCL | ![]() |
Monitor ID Bit 3 |
