QRZ.RU > Технические справочники > HwB: The Hardware Book (Mirror) > HwB: Universal Serial Bus (USB) (Tech) Connector
GoTo ConnectorCONNECTORGoTo Main
Universal Serial Bus (USB) (Technical)
USB was developed by Compaq, Digital Equipment Corp, IBM PC Co., Intel, Microsoft, NEC and Northern Telecom.
Features:
  • True Plug'n'Play.
  • Hot plug and unplug
  • Low cost
  • Easy of use
  • 127 physical devices
  • Low cost cables and connectors
Bandwidth:
  • Full speed: 12 Mbps speed (requires shielded cable)
  • Low speed: 1.5 Mbps speed (non-shielded cable)
Definitions:
USB Host = The computer, only one host per USB system.
USB Device = A hub or a Function.
Power usage:
Bus-powered hubs: Draw Max 100 mA at power up and 500 mA normally.
Self-powered hubs: Draw Max 100 mA, must supply 500 mA to each port.
Low power, bus-powered functions: Draw Max 100 mA.
High power, bus-powered functions: Self-powered hubs: Draw Max 100 mA, must supply 500 mA to each port.
Self-powered functions: Draw Max 100 mA.
Suspended device: Max 0.5 mA
Voltage:
  • Supplied voltage by a host or a powered hub ports is between 4.75 V and 5.25 V.
  • Maximum voltage drop for bus-powered hubs is 0.35 V from it's host or hub to the hubs output port.
  • All hubs and functions must be able to send configuration data at 4.4 V, but only low-power functions need to be working at this voltage.
  • Normal operational voltage for functions is minimum 4.75 V.
Shielding:
Shield should only be connected to Ground at the host. No device should connect Shield to Ground.
Cable:
Shielded:
Data: 28 AWG twisted
Power: 28 AWG - 20 AWG non-twisted
Non-shielded:
Data: 28 AWG non-twisted
Power Gauge Max length
28 0.81 m
26 1.31 m
24 2.08 m
22 3.33 m
20 5.00 m
Cable colors:
Pin Name Cable color Description
1 VCC Red +5 VDC
2 D- White Data -
3 D+ Green Data +
4 GND Black Ground
Contributor: Joakim Цgren
Sources: USB FAQ at USB Implementers Forum
Sources: USB Specification v1.0 at
Please send any comments to Joakim Цgren.
