QRZ.RU > Технические справочники > HwB: The Hardware Book (Mirror) > HwB: SCSI Internal (Single-ended) Connector
SCSI=Small Computer System Interface.
Based on an original design by Shugart Associates. SCSI was
ratified in 1986.
(At the controller & harddisk)
(At the cable.)
50 PIN IDC MALE at the controller & harddisk.
50 PIN IDC FEMALE at the cable.
Pin | Name | Dir | Description |
2 | DB0 | ![]() |
Data Bus 0 |
4 | DB1 | ![]() |
Data Bus 1 |
6 | DB2 | ![]() |
Data Bus 2 |
8 | DB3 | ![]() |
Data Bus 3 |
10 | DB4 | ![]() |
Data Bus 4 |
12 | DB5 | ![]() |
Data Bus 5 |
14 | DB6 | ![]() |
Data Bus 6 |
16 | DB7 | ![]() |
Data Bus 7 |
18 | PARITY | ![]() |
Data Parity (odd Parity) |
20 | GND | ![]() |
Ground |
22 | GND | ![]() |
Ground |
24 | GND | ![]() |
Ground |
26 | TMPWR | ![]() |
Termination Power |
28 | GND | ![]() |
Ground |
30 | GND | ![]() |
Ground |
32 | /ATN | ![]() |
Attention |
34 | GND | ![]() |
Ground |
36 | /BSY | ![]() |
Busy |
38 | /ACK | ![]() |
Acknowledge |
40 | /RST | ![]() |
Reset |
42 | /MSG | ![]() |
Message |
44 | /SEL | ![]() |
Select |
46 | /C/D | ![]() |
Control/Data |
48 | /REQ | ![]() |
Request |
50 | /I/O | ![]() |
Input/Output |
All odd-numbered pins, except pin 25, are connected to ground. Pin 25 is left open.
Contributor: Joakim Цgren Source: ? Please send any comments to Joakim Цgren.
