QRZ.RU > Технические справочники > HwB: The Hardware Book (Mirror) > HwB: SCSI External D-Sub (Future Domain) Connector
Seems to be available on some Future Domain SCSI-controllers only.
(At the controller)
(At the cable)
25 PIN D-SUB FEMALE at the controller.
25 PIN D-SUB MALE at the cable.
Pin | Name | Dir | Description |
1 | GND | Ground | |
2 | DB1 | Data Bus 1 | |
3 | DB3 | Data Bus 3 | |
4 | DB5 | Data Bus 5 | |
5 | DB7 | Data Bus 7 | |
6 | GND | Ground | |
7 | /SEL | Select | |
8 | GND | Ground | |
9 | TMPWR | Termination Power | |
10 | /RST | Reset | |
11 | C/D | Control/Data | |
12 | I/O | Input/Output | |
13 | GND | Ground | |
14 | DB0 | Data Bus 0 | |
15 | DB2 | Data Bus 2 | |
16 | DB4 | Data Bus 4 | |
17 | DB6 | Data Bus 6 | |
18 | PARITY | Data Parity | |
19 | GND | Ground | |
20 | /ATN | Attention | |
21 | /MSG | Message | |
22 | /ACK | Acknowledge | |
23 | BSY | Busy | |
24 | /REQ | Request | |
25 | GND | Ground |
