QRZ.RU > Технические справочники > HwB: The Hardware Book (Mirror) > HwB: SCSI-II External Hi D-Sub (Single-ended) Connector
(At
the controller & devices).
(To
the cable).
50 PIN HI-DENSITY D-SUB FEMALE at the controller &
devices.
50 PIN HI-DENSITY D-SUB MALE at the cable.
Pin | Name | Dir | Description |
1-25 | GND | ![]() |
Ground |
26 | DB0 | ![]() |
Data Bus 0 |
27 | DB1 | ![]() |
Data Bus 1 |
28 | DB2 | ![]() |
Data Bus 2 |
29 | DB3 | ![]() |
Data Bus 3 |
30 | DB4 | ![]() |
Data Bus 4 |
31 | DB5 | ![]() |
Data Bus 5 |
32 | DB6 | ![]() |
Data Bus 6 |
33 | DB7 | ![]() |
Data Bus 7 |
34 | PARITY | ![]() |
Data Parity (odd Parity) |
35 | GND | ![]() |
Ground |
36 | GND | ![]() |
Ground |
37 | GND | ![]() |
Ground |
38 | TMPWR | ![]() |
Termination Power |
39 | GND | ![]() |
Ground |
40 | GND | ![]() |
Ground |
41 | /ATN | ![]() |
Attention |
42 | n/c | - | Not connected |
43 | /BSY | ![]() |
Busy |
44 | /ACK | ![]() |
Acknowledge |
45 | /RST | ![]() |
Reset |
46 | /MSG | ![]() |
Message |
47 | /SEL | ![]() |
Select |
48 | /C/D | ![]() |
Control/Data |
49 | /REQ | ![]() |
Request |
50 | /I/O | ![]() |
Input/Output |
