HwB: RS422 Connector
RS422
(At the DTE)
(At the DCE)
37 PIN D-SUB MALE at the DTE (Computer).
37 PIN D-SUB FEMALE at the DCE (Modem).
Pin | Name | Dir | Description |
1 | GND | ![]() |
Shield Ground |
2 | SRI | ![]() |
Signal Rate Indicator |
3 | n/c | - | Spare |
4 | SD | ![]() |
Send Data |
5 | ST | ![]() |
Send Timing |
6 | RD | ![]() |
Receive Data |
7 | RTS | ![]() |
Request To Send |
8 | RR | ![]() |
Receiver Ready |
9 | CTS | ![]() |
Clear To Send |
10 | LL | ![]() |
Local Loopback |
11 | DM | ![]() |
Data Modem |
12 | TR | ![]() |
Terminal Ready |
13 | RR | ![]() |
Receiver Ready |
14 | RL | ![]() |
Remote Loopback |
15 | IC | ![]() |
Incoming Call |
16 | SF/SR | ![]() |
Select Frequency/Select Rate |
17 | TT | ![]() |
Terminal Timing |
18 | TM | ![]() |
Test Mode |
19 | GND | ![]() |
Ground |
20 | RC | ![]() |
Receive Twister-Pair Common |
21 | GND | ![]() |
Spare Twister-Pair Return |
22 | /SD | ![]() |
Send Data TPR |
23 | GND | ![]() |
Send Timing TPR |
24 | GND | ![]() |
Receive Timing TPR |
25 | /RS | ![]() |
Request To Send TPR |
26 | /RT | ![]() |
27 | /CS | ![]() |
Clear To Send TPR |
28 | IS | ![]() |
Terminal In Service |
29 | /DM | ![]() |
Data Mode TPR |
30 | /TR | ![]() |
Terminal Ready TPR |
31 | /RR | ![]() |
Receiver TPR |
32 | SS | ![]() |
Select Standby |
33 | SQ | ![]() |
Signal Quality |
34 | NS | ![]() |
New Signal |
35 | /TT | ![]() |
Terminal Timing TPR |
36 | SB | ![]() |
Standby Indicator |
37 | SC | ![]() |
Send Twister Pair Common |
