HwB: Parallel (PC) Connector
Parallel (PC)
(At the PC)
25 PIN D-SUB FEMALE at the PC.
Pin | Name | Dir | Description |
1 | /STROBE | ![]() |
Strobe |
2 | D0 | ![]() |
Data Bit 0 |
3 | D1 | ![]() |
Data Bit 1 |
4 | D2 | ![]() |
Data Bit 2 |
5 | D3 | ![]() |
Data Bit 3 |
6 | D4 | ![]() |
Data Bit 4 |
7 | D5 | ![]() |
Data Bit 5 |
8 | D6 | ![]() |
Data Bit 6 |
9 | D7 | ![]() |
Data Bit 7 |
10 | /ACK | ![]() |
Acknowledge |
11 | BUSY | ![]() |
Busy |
12 | PE | ![]() |
Paper End |
13 | SEL | ![]() |
Select |
14 | /AUTOFD | ![]() |
Autofeed |
15 | /ERROR | ![]() |
Error |
16 | /INIT | ![]() |
Initialize |
17 | /SELIN | ![]() |
Select In |
18 | GND | ![]() |
Signal Ground |
19 | GND | ![]() |
Signal Ground |
20 | GND | ![]() |
Signal Ground |
21 | GND | ![]() |
Signal Ground |
22 | GND | ![]() |
Signal Ground |
23 | GND | ![]() |
Signal Ground |
24 | GND | ![]() |
Signal Ground |
25 | GND | ![]() |
Signal Ground |
