QRZ.RU > Технические справочники > HwB: The Hardware Book (Mirror) > HwB: Parallel (Olivetti M10) Connector
Available on an old portable computer called Olivetti M10.
(At the Computer)
26 PIN IDC MALE at the Computer.
Pin | Name | Dir | Description |
1 | /STROBE | ![]() |
Strobe |
2 | D0 | ![]() |
Data Bit 0 |
3 | D1 | ![]() |
Data Bit 1 |
4 | D2 | ![]() |
Data Bit 2 |
5 | D3 | ![]() |
Data Bit 3 |
6 | D4 | ![]() |
Data Bit 4 |
7 | D5 | ![]() |
Data Bit 5 |
8 | D6 | ![]() |
Data Bit 6 |
9 | D7 | ![]() |
Data Bit 7 |
10 | /ACK | ![]() |
Acknowledge |
11 | BUSY | ![]() |
Busy |
12 | PE | ![]() |
Paper End |
13 | SELIN | ![]() |
Select In |
14 | GND | ![]() |
Signal Ground |
15 | GND | ![]() |
Signal Ground |
16 | GND | ![]() |
Signal Ground |
17 | GND | ![]() |
Signal Ground |
18 | GND | ![]() |
Signal Ground |
19 | GND | ![]() |
Signal Ground |
20 | GND | ![]() |
Signal Ground |
21 | GND | ![]() |
Signal Ground |
22 | GND | ![]() |
Signal Ground |
23 | GND | ![]() |
Signal Ground |
24 | GND | ![]() |
Signal Ground |
25 | RESETGND | ![]() |
Reset Ground |
26 | /RESET | ![]() |
Reset |
