HwB: ECP Parallel Connector
ECP Parallel
ECP = Extended Capabilities Port
(At the PC)
25 PIN D-SUB FEMALE at the PC.
Pin | Name | Dir | Description |
1 | nStrobe | ![]() |
Strobe |
2 | data0 | ![]() |
Address, Data or RLE Data Bit 0 |
3 | data1 | ![]() |
Address, Data or RLE Data Bit 1 |
4 | data2 | ![]() |
Address, Data or RLE Data Bit 2 |
5 | data3 | ![]() |
Address, Data or RLE Data Bit 3 |
6 | data4 | ![]() |
Address, Data or RLE Data Bit 4 |
7 | data5 | ![]() |
Address, Data or RLE Data Bit 5 |
8 | data6 | ![]() |
Address, Data or RLE Data Bit 6 |
9 | data7 | ![]() |
Address, Data or RLE Data Bit 7 |
10 | /nAck | ![]() |
Acknowledge |
11 | Busy | ![]() |
Busy |
12 | PError | ![]() |
Paper End |
13 | Select | ![]() |
Select |
14 | /nAutoFd | ![]() |
Autofeed |
15 | /nFault | ![]() |
Error |
16 | /nInit | ![]() |
Initialize |
17 | /nSelectIn | ![]() |
Select In |
18 | GND | ![]() |
Signal Ground |
19 | GND | ![]() |
Signal Ground |
20 | GND | ![]() |
Signal Ground |
21 | GND | ![]() |
Signal Ground |
22 | GND | ![]() |
Signal Ground |
23 | GND | ![]() |
Signal Ground |
24 | GND | ![]() |
Signal Ground |
25 | GND | ![]() |
Signal Ground |
