QRZ.RU > Технические справочники > HwB: The Hardware Book (Mirror) > HwB: Parallel (Amiga) Connector
Parallel (Amiga)
(At the Amiga)
25 PIN D-SUB FEMALE at the Amiga.
Pin | Name | Dir | Description |
1 | /STROBE | ![]() |
Strobe |
2 | D0 | ![]() |
Data Bit 0 |
3 | D1 | ![]() |
Data Bit 1 |
4 | D2 | ![]() |
Data Bit 2 |
5 | D3 | ![]() |
Data Bit 3 |
6 | D4 | ![]() |
Data Bit 4 |
7 | D5 | ![]() |
Data Bit 5 |
8 | D6 | ![]() |
Data Bit 6 |
9 | D7 | ![]() |
Data Bit 7 |
10 | /ACK | ![]() |
Acknowledge |
11 | BUSY | ![]() |
Busy |
12 | POUT | ![]() |
Paper Out |
13 | SEL | ![]() |
Select (Shared with RS232 RING-indicator) |
14 | +5V PULLUP | ![]() |
+5 Volts DC (10 mA max) |
15 | n/c | - | Not connected. |
16 | /RESET | ![]() |
Reset |
17 | GND | ![]() |
Signal Ground |
18 | GND | ![]() |
Signal Ground |
19 | GND | ![]() |
Signal Ground |
20 | GND | ![]() |
Signal Ground |
21 | GND | ![]() |
Signal Ground |
22 | GND | ![]() |
Signal Ground |
23 | GND | ![]() |
Signal Ground |
24 | GND | ![]() |
Signal Ground |
25 | GND | ![]() |
Signal Ground |
