HwB: Parallel (Amiga 1000) Connector
GoTo ConnectorCONNECTORGoTo Main
25 PIN D-SUB MALE (At the Amiga 1000)
25 PIN D-SUB MALE at the Amiga 1000.
Pin Name Dir Description
1 /STROBE --> Strobe
2 D0 <-> Data Bit 0
3 D1 <-> Data Bit 1
4 D2 <-> Data Bit 2
5 D3 <-> Data Bit 3
6 D4 <-> Data Bit 4
7 D5 <-> Data Bit 5
8 D6 <-> Data Bit 6
9 D7 <-> Data Bit 7
10 /ACK <-- Acknowledge
11 BUSY <-> Busy
12 POUT <-> Paper Out
13 SEL <-> Select (Shared with RS232 RING-indicator)
14 GND --- Signal Ground
15 GND --- Signal Ground
16 GND --- Signal Ground
17 GND --- Signal Ground
18 GND --- Signal Ground
19 GND --- Signal Ground
20 GND --- Signal Ground
21 GND --- Signal Ground
22 GND --- Signal Ground
23 +5V --> +5 Volts DC (10 mA max)
24 n/c - Not connected.
25 /RESET --> Reset
Note: Direction is Computer relative Peripheral.
Contributor: Joakim Цgren
Source: Amiga 4000 User's Guide from Commodore
Please send any comments to Joakim Цgren.
