QRZ.RU > Технические справочники > HwB: The Hardware Book (Mirror) > HwB: Novell and Procomp External SCSI Connector
This interface is nowadays considered obsolete.
(At the controller)
37 PIN D-SUB FEMALE at the controller.
Pin | Name | Dir | Description |
1 | GND | ![]() |
Ground |
2 | GND | ![]() |
Ground |
3 | GND | ![]() |
Ground |
4 | GND | ![]() |
Ground |
5 | GND | ![]() |
Ground |
6 | GND | ![]() |
Ground |
7 | GND | ![]() |
Ground |
8 | GND | ![]() |
Ground |
9 | GND | ![]() |
Ground |
10 | GND | ![]() |
Ground |
11 | GND | ![]() |
Ground |
12 | GND | ![]() |
Ground |
13 | GND | ![]() |
Ground |
14 | GND | ![]() |
Ground |
15 | GND | ![]() |
Ground |
16 | GND | ![]() |
Ground |
17 | GND | ![]() |
Ground |
18 | GND | ![]() |
Ground |
19 | TERMPWR | ![]() |
Termination Power |
20 | /DB0 | ![]() |
Data Bus 0 |
21 | /DB1 | ![]() |
Data Bus 1 |
22 | /DB2 | ![]() |
Data Bus 2 |
23 | /DB3 | ![]() |
Data Bus 3 |
24 | /DB4 | ![]() |
Data Bus 4 |
25 | /DB5 | ![]() |
Data Bus 5 |
26 | /DB6 | ![]() |
Data Bus 6 |
27 | /DB7 | ![]() |
Data Bus 7 |
28 | /DBP | ![]() |
Data Bus Parity |
29 | /ATN | ![]() |
Attention |
30 | /BSY | ![]() |
Busy |
31 | /ACK | ![]() |
Acknowledge |
32 | /RST | ![]() |
Reset |
33 | /MSG | ![]() |
Message |
34 | /SEL | ![]() |
Select |
35 | /C/D | ![]() |
Control/Data |
36 | /REQ | ![]() |
Request |
37 | /I/O | ![]() |
Input/Output |
