HwB: Miniature Card Connector
Miniature Card
Developed by Intel.
Miniature Card is a memory-only expansion card.
(At the device)
(At the card)
UNKNOWN CONNECTOR at the device.
UNKNOWN CONNECTOR at the card.
Pin | Name | Description | Dir |
1 | A18 | Address Bus | |
2 | A16 | Address Bus | |
3 | A14 | Address Bus | |
4 | Vccr | Voltage Refresh | |
5 | CEH# | Card Enable High Byte | |
6 | A11 | Address Bus | |
7 | A9 | Address Bus | |
8 | A8 | Address Bus | |
9 | A6 | Address Bus | |
10 | A5 | Address Bus | |
11 | A3 | Address Bus | |
12 | A2 | Address Bus | |
13 | A0 | Address Bus | |
14 | RAS# | Row Address Strobe | |
15 | A24 | Address Bus | |
16 | A23 | Address Bus | |
17 | A22 | Address Bus | |
18 | OE# | Output Enable | |
19 | D15 | Data Bus | |
20 | D13 | Data Bus | |
21 | D12 | Data Bus | |
22 | D10 | Data Bus | |
23 | D9 | Data Bus | |
24 | D0 | Data Bus | |
25 | D2 | Data Bus | |
26 | D4 | Data Bus | |
27 | RFU | Reserved for future use | |
28 | D7 | Data Bus | |
29 | SDA | Serial Data and Address | |
30 | SCL | Serial Clock | |
31 | A19 | Address Bus | |
32 | A17 | Address Bus | |
33 | A15 | Address Bus | |
34 | A13 | Address Bus | |
35 | A12 | Address Bus | |
36 | RESET# | Reset | |
37 | A10 | Address Bus | |
38 | VS1# | Voltage Sense 1 | |
39 | A7 | Address Bus | |
40 | BS8# | Bus Size 8 | |
41 | A4 | Address Bus | |
42 | CEL# | Card Enable Low Byte | |
43 | A1 | Address Bus | |
44 | CASL# | Column Address Strobe Low Byte | |
45 | CASH# | Column Address Strobe High Byte | |
46 | CD# | Card Detect | |
47 | A21 | Address Bus | |
48 | BUSY# | Ready/Busy | |
49 | WE# | Write Enable | |
50 | D14 | Data Bus | |
51 | RFU | Reserved for future use | |
52 | D11 | Data Bus | |
53 | VS2# | Voltage Sense 2 | |
54 | D8 | Data Bus | |
55 | D1 | Data Bus | |
56 | D3 | Data Bus | |
57 | D5 | Data Bus | |
58 | D6 | Data Bus | |
59 | RFU | Reserved for future use | |
60 | A20 | Address Bus |
The following three is separate:
GND | Ground | |
VCC | Power | |
CINS# | Card Insertion |
Contributor: Joakim Цgren
Source: Minicature Card v1.1 spec at Miniature Card Implementers Forum's homepage Please send any comments to Joakim Цgren.
