HwB: IDE Internal Connector
IDE Internal
IDE=Integrated Drive Electronics.
Developed by Compaq and Western Digital.
Newer version of IDE goes under the name ATA=AT bus Attachment.
(At the controller & peripherals)
(At the cable)
40 PIN IDC MALE at the controller & peripherals.
40 PIN IDC FEMALE at the cable.
Pin | Name | Dir | Description |
1 | /RESET | ![]() |
Reset |
2 | GND | ![]() |
Ground |
3 | DD7 | ![]() |
Data 7 |
4 | DD8 | ![]() |
Data 8 |
5 | DD6 | ![]() |
Data 6 |
6 | DD9 | ![]() |
Data 9 |
7 | DD5 | ![]() |
Data 5 |
8 | DD10 | ![]() |
Data 10 |
9 | DD4 | ![]() |
Data 4 |
10 | DD11 | ![]() |
Data 11 |
11 | DD3 | ![]() |
Data 3 |
12 | DD12 | ![]() |
Data 12 |
13 | DD2 | ![]() |
Data 2 |
14 | DD13 | ![]() |
Data 13 |
15 | DD1 | ![]() |
Data 1 |
16 | DD14 | ![]() |
Data 14 |
17 | DD0 | ![]() |
Data 0 |
18 | DD15 | ![]() |
Data 15 |
19 | GND | ![]() |
Ground |
20 | KEY | - | Key |
21 | n/c | - | Not connected |
22 | GND | ![]() |
Ground |
23 | /IOW | ![]() |
Write Strobe |
24 | GND | ![]() |
Ground |
25 | /IOR | ![]() |
Read Strobe |
26 | GND | ![]() |
Ground |
27 | IO_CH_RDY | ![]() |
28 | ALE | ![]() |
Address Latch Enable |
29 | n/c | - | Not connected |
30 | GND | ![]() |
Ground |
31 | IRQR | ![]() |
Interrupt Request |
32 | /IOCS16 | ? | IO ChipSelect 16 |
33 | DA1 | ![]() |
Address 1 |
34 | n/c | - | Not connected |
35 | DA0 | ![]() |
Address 0 |
36 | DA2 | ![]() |
Address 2 |
37 | /IDE_CS0 | ![]() |
(1F0-1F7) |
38 | /IDE_CS1 | ![]() |
(3F6-3F7) |
39 | /ACTIVE | ![]() |
Led driver |
40 | GND | ![]() |
Ground |
