HwB: Centronics Connector
Centronics
(At the Printer)
36 PIN CENTRONICS FEMALE at the Printer.
Pin | Name | Dir | Description |
1 | /STROBE | Strobe | |
2 | D0 | Data Bit 0 | |
3 | D1 | Data Bit 1 | |
4 | D2 | Data Bit 2 | |
5 | D3 | Data Bit 3 | |
6 | D4 | Data Bit 4 | |
7 | D5 | Data Bit 5 | |
8 | D6 | Data Bit 6 | |
9 | D7 | Data Bit 7 | |
10 | /ACK | Acknowledge | |
11 | BUSY | Busy | |
12 | POUT | Paper Out | |
13 | SEL | Select | |
14 | /AUTOFEED | Autofeed | |
15 | n/c | - | Not used |
16 | 0 V | Logic Ground | |
17 | CHASSIS GND | Shield Ground | |
18 | +5 V PULLUP | +5 V DC (50 mA max) | |
19 | GND | Signal Ground (Strobe Ground) | |
20 | GND | Signal Ground (Data 0 Ground) | |
21 | GND | Signal Ground (Data 1 Ground) | |
22 | GND | Signal Ground (Data 2 Ground) | |
23 | GND | Signal Ground (Data 3 Ground) | |
24 | GND | Signal Ground (Data 4 Ground) | |
25 | GND | Signal Ground (Data 5 Ground) | |
26 | GND | Signal Ground (Data 6 Ground) | |
27 | GND | Signal Ground (Data 7 Ground) | |
28 | GND | Signal Ground (Acknowledge Ground) | |
29 | GND | Signal Ground (Busy Ground) | |
30 | /GNDRESET | Reset Ground | |
31 | /RESET | Reset | |
32 | /FAULT | Fault (Low when offline) | |
33 | 0 V | Signal Ground | |
34 | n/c | - | Not used |
35 | +5 V | +5 V DC | |
36 | /SLCT IN | Select In (Taking low or high sets printer on line or off line respectively) |
