HwB: CardBus Connector
GoTo ConnectorCONNECTORGoTo Main
CardBus
32-bit bus defined by PCMCIA.
68 PIN ??? MALE (At the controller)
68 PIN ??? FEMALE (At the peripherals)
68 PIN ??? MALE at the controller.
68 PIN ??? FEMALE at the peripherals.
Pin Name Description
1 GND Ground
2 CAD0 Address/Data 0
3 CAD1 Address/Data 1
4 CAD3 Address/Data 3
5 CAD5 Address/Data 5
6 CAD7 Address/Data 7
7 CCBE0# Command/Byte Enable 0
8 CAD9 Address/Data 9
9 CAD11 Address/Data 11
10 CAD12 Address/Data 12
11 CAD14 Address/Data 14
12 CCBE1# Command/Byte Enable 1
13 CPAR Parity
14 CPERR# Parity error
15 CGNT# Grant
16 CINT# Interrupt
17 Vcc Vcc
18 Vpp1 Vpp1
19 CCLK CCLK
20 CIRDY# Initiator Ready
21 CCBE2# Command/Byte Enable 2
22 CAD18 Address/Data 18
23 CAD20 Address/Data 20
24 CAD21 Address/Data 21
25 CAD22 Address/Data 22
26 CAD23 Address/Data 23
27 CAD24 Address/Data 24
28 CAD25 Address/Data 25
29 CAD26 Address/Data 26
30 CAD27 Address/Data 27
31 CAD29 Address/Data 29
32 RSRVD Reserved
33 CCLKRUN# CCLKRUN#
34 GND Ground
35 GND Ground
36 CCD1# Card Detect 1
37 CAD2 Address/Data 2
38 CAD4 Address/Data 4
39 CAD6 Address/Data 6
40 RSRVD Reserved
41 CAD8 Address/Data 8
42 CAD10 Address/Data 10
43 CVS1
44 CAD13 Address/Data 13
45 CAD15 Address/Data 15
46 CAD16 Address/Data 16
47 RSRVD Reserved
48 CBLOCK# Block ???
49 CSTOP# Stop transfer cycle
50 CDEVSEL# Device Select
51 Vcc Vcc
52 Vpp2 Vpp2
53 CTRDY# Target Ready
54 CFRAME# Address or Data phase
55 CAD17 Address/Data 17
56 CAD19 CAD19
57 CVS2
58 CRST# Reset
59 CSERR# System Error
60 CREQ# Request ???
61 CCBE3# Command/Byte Enable 3
62 CAUDIO Audio ???
63 CSTSCHG
64 CAD28 Address/Data 28
65 CAD30 Address/Data 30
66 CAD31 Address/Data 31
67 CCD2# Card Detect 2
68 GND Ground
Contributor: Joakim Цgren, Marek Hostasa
Source: PC Card Standard at PC Card's homepage
Please send any comments to Joakim Цgren.
