HwB: Amiga Video Connector
Amiga Video
(At the Amiga)
23 PIN D-SUB MALE at the Amiga.
Pin | Name | Dir | Description |
1 | /XCLK | ![]() |
Extern Clock |
2 | /XCLKEN | ![]() |
Extern Clock Enable (47 Ohm) |
3 | RED | ![]() |
Analog Red (75 Ohm) |
4 | GREEN | ![]() |
Analog Green (75 Ohm) |
5 | BLUE | ![]() |
Analog Blue (75 Ohm) |
6 | DI | ![]() |
Digital Intensity (47 Ohm) |
7 | DR | ![]() |
Digital Red (47 Ohm) |
8 | DG | ![]() |
Digital Green (47 Ohm) |
9 | DB | ![]() |
Digital Blue (47 Ohm) |
10 | /CSYNC | ![]() |
Composite Sync (47 Ohm) |
11 | /HSYNC | ![]() |
Horizontal Sync (47 Ohm) |
12 | /VSYNC | ![]() |
Vertical Sync (47 Ohm) |
13 | GNDRTN | ![]() |
Digital Ground (for /XCLKEN) Don't connect with pin 16-20. |
14 | /PIXELSW | ![]() |
Genlock overlay (47 Ohm) |
15 | /C1 | ![]() |
Clock out (47 Ohm) |
16 | GND | ![]() |
Video Ground |
17 | GND | ![]() |
Video Ground |
18 | GND | ![]() |
Video Ground |
19 | GND | ![]() |
Video Ground |
20 | GND | ![]() |
Video Ground |
21 | -12V | ![]() |
-12 Volts DC (10 mA max) (A500/A600/A1200) |
-5V | ![]() |
-5 Volts DC (10 mA max) (A1000/A2000/A3000/A4000) | |
22 | +12V | ![]() |
+12 Volts DC (100 mA max) |
23 | +5V | ![]() |
+5 Volts DC (100 mA max) |
