HwB: PC 2 Joysticks Adapter
GoTo AdapterADAPTERGoTo Main
PC 2 Joysticks adapter
This adapter will make it possible to connect 1 extra joystick to the PC. The gameport contains pins for two joysticks but you will need this adapter to be able to connect two joysticks to one connector.
15 PIN D-SUB MALE (To the Computer)
15 PIN D-SUB FEMALE (To the 1st Joystick)
15 PIN D-SUB FEMALE (To the 2nd Joystick)
15 PIN D-SUB MALE to the Computer.
15 PIN D-SUB FEMALE to the 1st Joystick.
15 PIN D-SUB FEMALE to the 2nd Joystick.
PC Joy 1 Joy 2
+5 VDC 1 1 -
Button 1 2 2
Joystick 1 - X 3 3
Ground 4 4 4
Ground 5 5 5
Joystick 1 - Y 6 6
Button 2 7 7
+5 VDC 8 8
+5 VDC 9 9 1
Button 4 10 10 2
Joystick 2 - X 11 11 3
Ground 12 12
Joystick 2 - Y 13 13 6
Button 3 14 14 7
+5 VDC 15 15 8
Note: Since pin 12 is often used for MIDI-signals on gameport equipped soundcards it's better to use the ground from pin 4 & 5, pin 15 is also used for MIDI-signals...
Contributor: Joakim Цgren
Source: Tomi Engdahl's Joystick page
Please send any comments to Joakim Цgren.
