QRZ.RU > Технические справочники > HwB: The Hardware Book (Mirror) > HwB: Centronics to LapLink Adapter
This adapter will allow you to use a normal printercable (Centronics) as a LapLink/InterLink cable.
(To the
Printer cable)
(To the Computer)
36 PIN CENTRONICS FEMALE to the Printer cable.
25 PIN D-SUB MALE to the Computer.
Name | 36-Cen | 25-DSub | Name |
Data Bit 0 | 2 | 15 | Error |
Data Bit 1 | 3 | 13 | Select |
Data Bit 2 | 4 | 12 | Paper Out |
Data Bit 3 | 5 | 10 | Acknowledge |
Data Bit 4 | 6 | 11 | Busy |
Acknowledge | 10 | 5 | Data Bit 3 |
Busy | 11 | 6 | Data Bit 4 |
Paper Out | 12 | 4 | Data Bit 2 |
Select | 13 | 3 | Data Bit 1 |
Error | 32 | 2 | Data Bit 0 |
Reset | 16 | 16 | Reset |
Select | 17 | 17 | Select |
Signal Ground | 19-30+33 | 18-25 | Signal Ground |
